Help with strapping Orions
ruger
quick help with 2 orion d1200's, trying to strap them.
this is were im at so far
the amps come on and the Power and ESP light both light up ?
im not getting any sound out of the sub unless i turn the radio up to max,
then there is a faint sound like its barely on. i messed with the h/u already and made shur the sub was on and in mono mode and rca's were in .
rewired the amps in a 4ohm mode and the same thing happens, what exactly is the ESP port? do i need to use that wire to connect the two. the manual is a little vauge on that?
also do i need to use a second rca in the slave amp?
any help would be great //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
tryed running the speakers center + and - together to run in a 4 ohm mode
and same thing.
power -green light on
ESP - yellow light on constant
Protect - red light not on
dont really understand this, these amps love 1ohm. im shur im just making a noob mistake, trying to strap these. gonna just run one each per coil for now.
bump
stayed up late last night tring to figure this out.
wired each amp seprate into 1 ohm on the sub, both amps run fine.
so anyone know what im missing here?
ruger
ruger
USA
ruger
BP1Fanatic
BP1Fanatic
