Help with speaker setup!!
ChuckNaked
NY
I'm new to this guys so if you guys can help me out with deciding which setup is best for me that would be cool. I have some questions about what speaker setup I should choose for a 96 Maxima 4 door sedan. I don’t want a big subwoofer in the trunk, so no subwoofer. I do want to have bass in the car but not the kind a subwoofer from the trunk brings. I’m not interested in hearing the car rattle. I do want to be able to hear high sounds such as the one used in classical music and I want an adequate bass for when I pump my beats.
For the front door I was thinking about going with a component speaker system because I want clear clean sound. Would I get the same results if I used 2 3-way speakers in the front doors instead of a component system? Also do I place the woofer where the current speaker is now? Where does the crossover go?
For the rear deck I was looking at some mid-ranges Kickers or some 3-way speakers. Can you please tell me the difference? Which one will provide clear sound and adequate bass? I assuming the mid-range have more bass but the 3-way has more quality sound, is this correct? Any other advantages of a 3-way over the mid-range?
Also I wanted to know where I should mount the amp. I assuming for the setup I listed above I need a 4 channel amp. I know I heard an amp needs air to breath so it doesn’t get hot, so should it go in the trunk or under the seat? I assuming in the trunk.
Thanks in advance to anyone who can help me out with helping me pick the setup.
Charlie
I would get a set of nice comps up front, a cheaper set of 2 or threeways in the back. Amp them and it should sound pretty good. How much are you looking to spend. I put my amp in the trunk because it couldnt fit anywhere else but your car may allow for other places but make sure it gets good cooling. Oh and components will definitely sound better unless you buy some pretty crappy ones.
Do this, get a pair of nice components like focal, crystal, Mb quart, rainbow, infinity, many others...for the front. And u wont need anything for the back but if u really want something back there grab some Midbass drivers. Make sure u have a nice amp to power them , something like 80 watts per channel. And make sure to have a nice Deck as it makes a big difference
Hi Charlie, My name is Ove Taylor i live in NewZealand, Right what you want to do is get some 2way (aprox 6-7inch) speakers for the front doors, and some 6x9's for the back window sill (this is how ive got mine set up and i love it). Put your amp under the passengers seat, and run the wires under the carpeting in your car. The head unit you have (i dont know) all depends on the settings your using, using all four channels on the amp is good. If you can Bridge the 6x9's this will give you more power and have the front on one channel each. see how this goes...
Thanks guys for all your suggestions. I think I'm going to go with the components in the front, some mid-ranges in the back and a amp under the seat. Lombardo (or any of you guys) can you please tell me more about what happens when speakers in the rear deck have too much treble and start messing up the sound stage.
Chuck
ChuckNaked
ChuckNaked
NY
ChuckNaked
