capthooklv
I am ready to build my first slot ported box for a single Eclipse SW9152 15" woofer dual 4ohm voice coils. Going to wire in paralell and run it with an Orion 2500D mono at 2ohms. Speaker did not come with specs Eclipse factory said optimum is 4.75 cubic ft of air space with a slotted port 15" widex3" high x 18" long. This is going in the bed of my 2002 Ford F250 crewcab with shell firing upward.
When i try to make it work on the RE Enclosure calculator it gets tuned at 27hz has 4.753 cubic feet at box
made with 1"mdf)
width-35.2"
height-20"
depth-19"
square port width-3"
square port height-18"
square port length- 15"
Does this look right?
Should I round off the 1" mdf in port region?
Should i add any bracing?
Should I reinforce the plate that the speaker sits in and double up the wood thickness?
Should I drill pilot holes for all screws?
Does it matter what glue I use?
width-35.2"
height-20"
depth-19"
