I recently finished a sealed box for 4 ED KV2. Something short that I could hide and put stuff on top of. I have just over 4 ft to work with behind my seats and planned to use .5" mdf x 8.5" x 48" x 7". I should have factored in poly fill and shot for an even shallower box. For the subs, I was told to use the same calculations as for the newer e3.6 Subwoofer
small 0.2ft³
ideal 0.25ft³ is what I was shooting for.
large 0.3ft³
Displacement .04'^3 (x4 = .16'^3)
200watt rms each
At the home depot, I looked at the 1/2" mdf and decided to go with 3/4" jic.
So now the the box was supposed to be 9 x 48 x 7.5" external with 7.5 x 46.5 x 6" internal/ 1.21'^3 - (4x04'^3) 0.16'^3 = 1.05'^3. Bigger box...
I had them make the 4 main cuts... 2 x 9" strips for top and bottom and 2 x 6" for the sides. Left and started building the box. I just had to cut the two side strips and holes. Put the box together and wired it all up.
I'm running 300+ watts (400watt on birthsheet) from a pdx-5 into 2 ohms. Sounds a little muddy at times and not as tight as I was expecting. As I start installing the box to see if placement would help I notice there is no room between the box and my side panels. I measure it and it's an inch wider than it supposed to be. Still well within spec of .3'^per. I don't think it's leaking. Used liquid nails, a nail gun, and sealed the inside. It's pretty solid all in all. Maybe the subs displace less than I was told? So before I try to build a smaller box (
small 0.2ft³
large 0.3ft³
200watt rms each
