help with recone
yea i quoted him a price and told him i would build and ship no problem. i told him should build on better baskets that handle 8" spiders and still would be cheaper than anybody else //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
but also told him can build on those baskets...
If I'm not mistaken the AQ HDC recones and AB HD recones will fit that motor.
If it is the 3in konaki motor than I can also do it with lvl 5 softparts and as Corey mentioned it would require a standard 12spoke basket with an 8in spider landing. I also have shims you can buy for cheap to help you out //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Rob a lvl 5 recone will not work for this motor because it uses a 8 layer coil and wont fit the tight gap.
i have 2 diff coils i use in the 9500G,hdc,konaki a bifolar copper 3.150" and 3.180 flat wound alum.
i also have ways to make the motor cool better...
Interesting...we have reconed many aq hdc motors with lvl 5 parts and a basket swap. Does the hdc have a larger gap.
maybe ur's had a bigger gap in a tss,9500g you dont want any bigger than a 3.180" coil in there...
they are designed for a lightweight coil and up the bl with tight gap to make it more eff and better for burping....
87cadillac
87cadillac
Texas City, Tx
SPLaudio
BP1Fanatic
BP1Fanatic
