Help with power solution please!!!
stevenslrp
Can any one help with a power solution for this system I'm about to install in my car. My last install in my other car had light dimming, so I don't want to encounter the same problem here by under thinking anything.
Here's the set up
CAR : 94' Cutlass Supreme
Subwoofer : two 12's (Kickers CVR's) Rated at 800W and 400RMS 4 ohms DVC
Amp : 1 Kenwood KAC-8152D, (mono) 1100W 550RMS at 2ohm
Wires : 0/1 power/negative.
I need to know some power options, any upgrade to the car components if so. Recommended battery, cap if needed. Will appreciate the help if so.
Thanks
thats not a huge amount of power, but its always a good idea to do the big 3. i would say do that first and see if you get dimming. if so get a new batt upfront with a higher reserve capacity. and if thats not helping, and the battery that you have is rated to do enough watts then look into getting a new alt.
stevenslrp
stevenslrp
Muskegon, MI
audiolife
