ccapital83
if i run 2 subs that are each dvc2ohm so each sub will be wired at 1 ohm load. with my brutus amp it has 2 channels so if i connected both subs thaat way would the amp then see a .5 ohm load which i clearly dont want? if so im assuming id have to run these subs at 4 ohms each to create a final 2 ohm load? is this correct or will 2 subs @ 1 ohm each on a mono amp not drop the ohms past 1? help much appretiated!
