Light dimming with Sundown 2500 and Rockford 1000.4-ad
AndrewHD
Hello everyone. I am getting substantial dimming of interior and exterior lights when the bass hits on my FI BTL 15. I have a DC power 300amp alternator, Big 3 and single XS Power D3400. Since I am running about 3500 watts RMS do you think adding another D3400 will help eliminate the dimming? SAZ 2500 is wired at 1 ohm. Thanks guys
On the XS Power website it says adding a d3400 as a secondary battery will be good up to 4,000 watts. I already have one under the hood. Just wanted to see if this claim is true
I would still run a pair in the back. Your setup will be even happier. I would say start with one and go from there. I run a total of 3 3400s myself. I have dual Crescendos strapped @ 2 ohm for 4K. My 250 alt will ship this week, so I should be ok. No dimming at all right now on stock alt with the 3 batts. I do have dual runs of 1/0 wire ran from the front batt to the rear.
Yea we will see. 13.5V is the lowest it goes with my 300amp alternator and d3400 up front. I am hoping the extra d3400 will have enough reserve to keep it at least at 14.0V
---------- Post added at 09:24 PM ---------- Previous post was at 09:23 PM ----------
Do you have a dedicated ground? That was the only way to get rid of the dimming in my last setup.
Dedicated ground for what?
That extra Batt will surely help out quite a bit..As stated, try the edition, and if you still have issues, id add one more batt, but with the one under the hood, and the addition, you may be just fine:D..Let us know how it turns out if you decide to run the extra batt,and give us some reviews .
Iirc that batt is only 65ah get a 3100 for the rear if u can fit it and if you still have bad dimming run a ground from front batt to back batt
AndrewHD
AndrewHD
Orange County, CA
NASTY08IMPALA
