Help with ohm load...
Well right now I am running 1 RE SXx of a Cadence A7HC and 1 SA10 off an Audiopipe APSM1300, and it sounds fine... Of course they each are on their own amp right now
YOU NEVER RUN A DIFFERENT CONFIGURATION OF SUBWOOFERS/ OHMS LOAD/SUBS, DUE TO DIFFERENT FREQUENCIES FOR EACH SUB/OHMS VALUE, AND RMS VALUE.. CREATES CALCULATION ISSUES, AND AMPLIFIER FAILURE/ SUB WOOFER FAILURE .bASICLY SONDS LIKE ****, AND RUINS SUBS, AND AMP DUE TO DIFFERENT hERTZ/ FREQ,IMPLIED.=TRASH!! HOPE YOU HAVE A DEEP POCKET, AS YOU ARE ONE OF THOSE THAT KEEP THE STEREO SHOP AROUND THE CORNER IN BUISNESS, SELLING CRAP!!//content.invisioncic.com/y282845/emoticons/handclap.gif.0c301076f534e244f0460706894f19e0.gif
Simmer. I asked for advice. And yes, RE, Sundown, Cadence, Audiopipe can all be purchased at the "stereo shop around the corner"
All im saying is right now im running 2 different subs (In 2 DIFFERENT locations) on 2 DIFFERENT amp and it sounds fine. It actually sounds great.
Im going to give it a try, and if it sounds like crap I will change my configuration. I might just run each sub on a separate amp, 1 APSM 1300 for each sub.
And I would not worry about how deep my pockets are, does not concern you.
So what I am trying to understand is it because I want to strap the amps that running 2 different subs might create an issue. That I can understand, but each sub on it's own amp, in completely different areas of the boat should not really be a problem except for "it looks ghetto".
agarabaghi
agarabaghi
Orlando, FL
agarabaghi
