help with new box
  • 5
photocrazy8
Probably doesn't like you
3,969
CA
I build a new box for one 15" mofo. It's 4.5 cubes at 35Hz. And for some reason it only seems to hit the lows really hard. I thought that the higher the tuning Hz the higher Hz will hit hard? lil help, thanks andrew
its a 15" subwoofer, dont expect hitting all the higher notes bc that isnt going to happen. Tuning the box higher just gives it a different range, not neccicerily lets it hit harder in the highs. Also, a higher bass note dosnt really make the sub hit hard, it it would just get really loud if the box was tuned to that spacific note range.
Cone size has very little to do with how low a driver will get.
What high notes are you looking to hit? Maybe you are expecting too much from a SUB bass driver, and you need to upgrade your mids?
in the box i had it in b4 it was hitting almost all ranges of bass, but now it only seems to hit the really deep lows.
would the box i have it in make it this way?
915
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
627
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
photocrazy8
photocrazy8
CA
mazdakid
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
