Hi, I'm sorry I've read the guides and much to my dismay I believe I may have been sold the wrong amplifier for my setup.
I recently purchased 2 JL 12W3V2-D4 (4 Ohm DVC) and was told that any of the amps I was looking at, at the time, would suit the speaker configuration. Each speaker is rated at 300w RMS (and 600w Peak, not that I paid much attention to this.)
So I opted for a slightly older Kicker kx500.2, Kicker was a good brand name as far as I knew.Which is a dual channel amp that can give out a constant 250w per channel. I figured that was a safe bet so that I couldn't mess up the speakers by overpowering them.
When I got back and researched a bit more I found that the amp was rated for 2 Ohm loads at 500w but only 250w at 4 ohm. Which would mean only 125w per speaker.
I looked into wiring diagrams and thought that if I wired them in bridged parallel that I could get 2 Ohm total and still have 250w per speaker?
To be honest I'm confused by it all and have read many threads trying to figure out how I could get the most out of this setup.
Does anyone have any advice? Whenever I put it into the wiring wizard I got a 1 ohm and 4 ohm configuration but no 2 ohm confguration. But this is different to what I calculated earlier.
Thanks in advance, I know there are probably hundreds of threads like this every day but I have searched and I have read a lot but I'm still confused by this. :
