tsgtwheeler
to start things off. I bought 2 12" kickers and a prefab enclosure to go under my seat of my 2006 chevy crew cab pickup and a american pro 2000watt amp for 200.00 not bad. only one channel on the amp worked so I had to wire them in series for a 4 ohm load. just tonight I bought a hifonics brutus 1210D. pulled the subs out and wired them in parrallel for a 1 ohm load. this inclosure is a sealed single chamber with polly fill. my problem is that it seems that the american pro amp seems to hit harder than the hifonics amp. the american pro is rated at 300 watts rms at 4 ohm and the hifonics amp rated at 1200 watts at 1 ohm rms is probably between 700 and 800 rms about 80% of overrated specs. could there be something wrong with this amp or setup wrong and setting help would be great. ie subsonic, bass eq, low pass.
setting right now
subsonic set to 15hz
bass eq set to 0
low pass at 12 oclock position
phase set to 0
level gain set to around 12 oclock
have the boos control pluged in and set to max seems no difference in pluged in or not should i even plug this thing in.any help would be great It seems these two subs should shake this truck apart even in a sealed enclosure.
setting right now
bass eq set to 0
phase set to 0
