Help With Head Unit Removal
Gtsurfer
4
USA
Hello, I have a 2000 Grand Am SE, I'm totally at a loss as of how to remove the head unit so I can run the wires from my amp to it. I've basically got everything done except the head unit wires and the power wire(which i've already figured out the route) Is there screws behind the unit that I'm just not seeing, or do I have to remove the front panel for the entire console area, then I can get to the head unit. ??????
That's actually one of the easiest cars you'll find. Just pry the dash bezel off around the radio; it's only held on with pressure clips. The ring around the key switch will pop out too, make sure not to let it get damaged. You might have move the shifter out of the way. After the dash bezel is off, three screws hold the factory radio in.
Gtsurfer
Gtsurfer
USA
KaeZoo
