Help with conecting wires from sub into amp
middlemaniac
Hi. I need help on the wires coming out of my two subwoofers going into the amp. Since my amp is 1ohm stable I wired my two 4ohm subwoofers down to 1ohm to get more power. I just need help on which +/- outlets to put the two wires coming from my subs should go in. The amp is like this ++-- and I am connecting the positive wire coming from my subs into the first + outlet, and the negative wire coming from the subs into the last - terminal. Is this correct???? Do I need to do anything with the terminals in between???
then if its mono it does not matter which they go to. your subs Dual 4ohm? so you have it wired like this your good.
i did that.....but want to know where the two wires that come out of the subs connect to the amp. The amp is like this ++-- and right now I have it connected to the first positive, and the last negative(is that right?)
middlemaniac
middlemaniac
Florida
middlemaniac
