Help with box plans
DDSC
Wang-aholic
Hey all, Im about to build a box and I just wanted a second opinion on my layout and what I should be expecting.
Sub: DD9515h with 2k rms
Box: 4.17 cu ft total - .23 ft sub displacement, port displacement is unknown (HELP!!!)
Port inside Diameter: 6.75"
Port Lenght: 15" without flares 16.25 with
Based on the port calculator here Products Menu I should be tuned to roughly 35 hz before factoring in port displacement. Does that sound about right to you guys and can anyone calculate the port displacement for me??
I also have another question, are there any pros or cons to having a short wide port vs a long narrow one
As far as the port ratio, having a short long port should not exceed a ratio of 9:1 or you will encounter port noise even if the area is still large enough. Because at the corners of a port, pressure increases dramatically due to boundary effects. The more "square" the port, the better acoustical output in regards to minimal distortion and timbre.
What port is 6.75"?
If I did the math correct, the port displacement is .625 cf without the flares.
Any idea what this should be tuned to? Have you built many boxes before? I can help if needed.
What port is 6.75"? If I did the math correct, the port displacement is .625 cf without the flares.
Its a port from an old kicker box I had laying around, tuning should be around 37 hz
Do you have a design yet? Are you building this yourself? I think you should try to make the box bigger and use a different port. That is just to small for the sub. DD recommends 70sqin of port and you have 36! It looks like two of the ports would work, but they would need to be much longer. I'd look into a slot port myself, and try to make the box bigger. You have a super sub - put it in a super box. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Duane
DDSC
Wang-aholic
DDSC
Jackson, MI
DDSC
