Help with box design 07 Silverado
It is a pretty small space.....cut up alot unless you go over the hump of the truck and it is at an angle.....dimensions are 6.5 inches deep 15 inches long and 11 inches wide.....thanks alot
if its sealed tkae you max dimensions and build around around those tis not so hard.
15 * 11 * 6.5 externally yields 13.5 * 9.5 * 5
thuse using .75 in wood would be about .4ft3 before driver displacement
with such small panels you could probably get away with using .5in wood.
15 * 11 *6.5 yields 14 * 10 * 5.5
that would be about .44ft3
agrant
agrant
KY
Worlddre
