help with amp...
KickerFTL
I just bought an MA HK1000D but when i hooked it up, the power light only stayed on for about 15 seconds then slowly dimmed out to nothing. Thinking I need to get ungraded electrical but not sure yet. Its 1000wrms btw if that helps. any advice?//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Were the speakers connected when this happened? What ohm are they and were they wired series/parallel? What size is the power cable? What is the voltage at the amp? Sounds defective to me, or maybe a bad connection, low remote wire voltage, low battery voltage.
I tired them with and without the speaker, im running it at 1 ohm and the amp is 1 ohm stable wired paralled, the power cable is only 4 gauge(thinkin thats the problem), and 2k watts 1k rms
lol turns out i just blew a fuse. Can't believe i never checked that but thanks for the help anyways guys //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
KickerFTL
KickerFTL
Elgin, IL
KickerFTL
