Help with amp selection
no use a mono block they are made for bass.that kicker will be too much power at 2 ohms for the w 0 woofers .look at an amp that will do 1000 watts rms at 1 ohm so it will do 500 at 2 ohms
also a budget would help so that we can recommend an amp for you
He has 2 of those woofers. They'll take 1k between the two of them.. Unless he means he wants to send a total of 500 to both..? You don't need a Left and Right channel for your substage. You'll want them both playing equally.
Ur subs are single 4 ohm so you can only wire to a 2ohm load.. So u need an amp that will do a min of 500@2ohm... If on a budget the AP mylows is selling would do well. Ur subs are 500max not 500rms.
876
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
579
That is correct. I like these as they are twisted pair and the RCA ends are thick and grip quite nicely...
984
kylecassidy23
kylecassidy23
long island new york
kylecassidy23
maylar
    Jun 2, 2024
    Jun 1, 2024
