Help With Aiwa deck/Kenwood amp prob.
  • 2
IowaBoomer
Hi, I'm doing this for a buddy of mine.
He has an Aiwa HU with Rear RCA outputs. He has been having problems with his amp not turning on. I went and I hooked it up in my car, with 6 (?) gauge wiring. It wouldn't turn on until I plugged the RCA inputs into the amp, so this tells me the amp is input sensative.
I dcecked his wiring behind his deck, and its clean. His fuses are good, and when I tapped the power and ground wires (4 gauge) I got spark. I am using a remote wire ran directly from the power wire as a test.
He just got brand new RCA cable to run, and that didnt help either.
What the hell is the problem?
I think it mite be the HU, not kicking power out to the RCAS. Does this sound like it might be it, and how can i check it?
Oh, and if he cant get it to work, is it possible to wire a 12W3 D6 to it so it wont shut down? I think i can get the amp for about $25...HURRAH. Maybe a midbass amp.... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
try running the rca's from his HU to your amp. this should tell you if his rca out is good or bad.
364
304
298
IowaBoomer
IowaBoomer
Walnut, IA
imral3
    May 24, 2024
