Help with a new system - BMW e46 330ci
  • Thread starter TaDe330
  • Replies 0
  • Views 519
TaDe330
Hello!
I'm new here and am fairly new to car audio systems. Next week I'm taking my car to an audio shop for an upgrade from the factory BMW speaker system. I've been talking to the guy at the shop and he says he has certain unused components which he wanted to use for himself but will rather buy an even more expensive system so he is selling them with a discount. I need you help in evaluating the components, if they are worth the price and if they will play well together.
Front system:
Ground Zero Uranium GZUC 165x
2 system
2x 165 mm, alu membrane
2x 25 mm, silk membrane
rms 130 W
max 200 W
SPL 91 dB
4 ohm
12 dB/oct.
PRICE: 300€
Amplifier for the front system:
SPL Dynamics S-6004
RMS Power 4 Ohm 4 x 150W
RMS Power 2 Ohm 4 x 250W
RMS Power 4 Ohm mono 2 x 500W
THD (A-weight)
Input sensitivity 200mV - 4.5 V
Low Pass (12/24 dB/oct) 40 - 4000 Hz
High Pass (12/24 dB/oct) 15 - 4000 Hz
Dimensions (W x H x L)
222 x 54 x 450 mm
PRICE: 400€
Subwoofer:
Boston Rally Series
Normal size: 10"
Peak Input Power: 350 watts
Continuous Power: 175 watts
Sensitivity: 1 watt/.5 meter 94dB
Amplifier for the subwoofer:
*still looking*
Insulation of doors: ~200€
Speakers in the rear panel:
*Some normal speakers for around 50€ that will be connected directly to the radio*
So what do you guys think? Are the prices fair? Would you add or change anything?
Thank you very much!
Regards,
Tadej
TaDe330
TaDe330
Slovenia
TaDe330
Mike Mccabe
