Help with a home audio project
I would assume you're looking at two channel stereo...
$250 is a rough budget.
For that price, I would recommend a vintage integrated amp off Ebay (forget the receiver unless you're really in need of an FM tuner) and a pair of small full range drivers in DIY cabinets.
If you're in need of a subwoofer amp as well, forget this project for now and save some more money.
DIY is nice if you want to do that, other wise you can get some decent sound JBL for pretty cheap (I know I know I just recommended Junk But Loud, but they sound better than those damn pod speakers and the cheap "line" speakers you can get). Amp wise, check around on eBay, and online warehouses. You can get good stuff cheap sometimes, Yamaha, some Sony, if you really wanna go CHEAP Insignia has an ok 2 channel amp you might have to do a little jury rigging to set the subs up but shouldn't be toooooo hard. What kinda music would you be listening to on this system most of the time?
Ok... I guess im not gonna be getting much of anything by going the DIY route. What kind of surrond sound systems could i get below $200 and still sound good and have good output. I would mostly listen to rock and techno.
I will jus use the Onyx woofers for another project
Biggest problems with Home-Theater-In-Boxes are...
- Lack of flexibility. If you don't like the components, generally it's hard to switch them or change things. And it's a PITA to integrate your own subwoofers to it.
- Design compromises to meet a certain price point. Sticking a 3" full range driver in tiny plastic enclosures doesn't come without a price, and that price usually is evident in what you hear.
Having said that, Onkyo makes what I'd consider one of the best HTIB-type setups out there...although I'm not sure if it fits in your budget.
Ok thanks! Ill look around Ebay for some Onkyo
You can get an Onkyo refurbished 5.1 channel receiver @ jandr.com for $150.
Then go on ebay and look for some good used bookshelf speakers from a good company such as Boston, Paradigm, Energy, Polk Audio, NHT, JBL, Klipsch, etc.
This is the BEST sound you can get for that price.
skadude016
skadude016
Canton, GA
qwerty778
vegang
vegang
