help wiring voice coils please
Four DVC 4 Ohm drivers, to get a nominal final load of 2 Ohms, should be wired like so:
//content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif
Welcome to the forum!
For future reference save this link into your faves ~
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
It's an unendingly handy reference guide. //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
Good luck getting your tunes set up!
Thank you so much this is obviosly a series wiring. So the +'s go to voice coil 1 and the negatives go to voice coil 2 and you jumper voice coil 1negative to voice coil 2 possitive right?
Each sub will have its own coils wired in series. From there, you will have four subs that are 8 ohm loads. Wiring these four subs in parallel will give you the final 2 ohm load.
But yes, you have the idea correct. It's just like the picture.
jrl
jrl
Reno Nevada
blackbonnie
