gyzo33
Have everything installed but a little confused here.
Equipment:
(Two) Pioneer TS-W308D2
~Frequency Response: 20 - 180Hz
~Sensitivity: 90dB
~Impedance: 2 ohm
~Voice Coil: Dual 4 Layer, Long Voice Coils
~Recommended Enclosure Use: 0.85 ~ 1.75 Cubic Feet
(One) Hifonics Brutus BRZ1700.1D
~2 ohms: 1200 watts x 1 chan.
~1 ohm: 1700 watts x 1 chan.
~Variable low-pass filter (35-250 Hz, 24 dB/octave)
~Subsonic filter (15-35 Hz, 24 dB/octave)
~Phase Shift: 0-180°
~Damping factor: >290
~Frequency response: 35-250 Hz
(One) Box
~ Holds 2 round 12" subwoofers
~Divided into 2 seperate Chambers
~.86 cubic feet per chamber
The diagram shows that I connect both positives together and both negative together. If this is correct, which positive and which negatives on the amp will connect them?
After this, at what levels do put these at?
Level
Phase
Bass EQ
Sub Sonic
Low Pass
Sorry if these have been answered before.
Equipment:
~Sensitivity: 90dB
~Impedance: 2 ohm
(One) Box
Level
Phase
Bass EQ
Sub Sonic
Low Pass
