Help wiring my subs to my amp.
BigOleDom
First off, I'll admit I am a somewhat newbie at car audio stuff, I know the basics about most every thing, and have installed head units and amps before. However one thing that I neep help with is the wires from the amp to the sub. Okay time for the specs of the stuff.
My amp is an older style power acoustik gothic series.
It is 520 watts max (125x 2RMS)
It is two channel and bridgeable
It also has high/low/crossovers (don't know what that means)
2 x 125 watts into 4 ohms RMS, 2 x 150 watts into 2 ohms RMS
Now for my subs, much newer.
Rockford Fosgate PL1-212
Woofer Size (inches) 12 x 2
Woofer Material Polypropylene
Enclosure Type Ported
Color Black
Pieces in System 1
Width (inches) 34-1/8
Height (inches) 15-3/8
Depth (inches) 16-1/4
Second Depth (inches) N/A
Connector Type Binding Posts
Frequency Response 20-200 Hz
Power Range (Watts RMS) 50-300
Maximum Wattage 600
Sensitivity 86 dB
Impedance 8 ohms
Parts Warranty 1 Year/Woofers only
Labor Warranty 1 Year/Woofers only
Okay here this goes, where trying to explain it so it may go easier I will make a key.
A-left negative on amp
B-left positive on amp
C-right negative on amp
D-right positive on amp
1-negative on left sub
2-positive on left sub
3-negative on right sub
3-positive on right sub
Any help would be appreciated with this part of wiring, thank you in advance for your time.
I also noticed that the ohms on the subs and the amp don't match up, How bad is that?
Will it fry my amp/subs or does it just make it a lot quieter?
if im thinking right, which i think i am, the subs are wired for 4 ohms in the box. and if im thinking right again, there should be only 1 +/- terminal, so just bridge them up to the power acoustic
No, there are 2 +/- terminals.
okay then, forget what i said about them being wired for 4 ohms.
4-positive on right sub
1 and 3 to A
2 and 4 to D
also if you have a newerish head unit, keep the cross over at full and adjust the high and low pass on the HU.
as long as your amp has a lower stable ohm load then what your putting to it, in your case 8, or 4 ohms, youll be fine.
BigOleDom
BigOleDom
Ohio
BigOleDom
