Help Wiring ALpine Type R for better bass?
karrmite
I have an hifonics 1700 watt amp i wired it like the diagram on the bottom and im not getting the bass i am looking for...
its not that powerfull do i need to bridge or something? I am completely lost and i though i would get some good loud bass like this.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_2-ohm_mono.jpg
but when i click on 4 ohm 4ohm is wired exaxtly the same as this 2 ohm?
can someone tell me if i wired it wrong and thats why i am not getting much bass?
Can someone please reply to this please?
Do i need to wire it at 1ohm?
Btw the subs are dual 2ohm i think i wired it to 2ohm correctly but it doesnt feel right.
If you put both positives together and both negatives together on a Dual 2 ohm woofer, its final impedence will be 1 ohm. If you wire both woofers in series the load will be .5 ohm. Now if you do positive to negative on both subwoofers the final load for each woofer will be 4 ohm. Then wired in series the final load to your amp will be 2 ohm. I think.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-2-ohm-2-ch-low-imp.jpg
I would suggest that you double check your wiring first to make sure the woofers are in phase. It can be an easy simple mistake that I have seen many customers make.
I have an hifonics 1700 watt amp i wired it like the diagram on the bottom and im not getting the bass i am looking for...its not that powerfull do i need to bridge or something? I am completely lost and i though i would get some good loud bass like this.
What voice coil config. do you have? If it is Dual 2 for both subwoofers.
This is the lowest you can go to be STABLE with that amp
end of story /thread
what size (cu ft) is it per sub and whats it tuned to. the biggest issue is you got dual 2 ohm subs when you need dual 4 to get the the final ohm load to get all that your amp has to offer.
all amps have a gain. look up how to set it correctly, do so, then report back. the box could also be holding you back a whole lot
karrmite
karrmite
United States
karrmite
