HELP! Wiring a sub.
fwb_1234
It's a DD9917. Quad 2 = can be wired as .5, 2, or 8
I want it wired to 2ohms.
How do I connect the wires. Here a couple of pics.
Here's a pic of the sub and the little wires.
Here's a diagram of the wires. Tell me to connect to what. Also, with such a design, do I just use the little plastic screw on wire nuts to hook the wires together?
This is a wire nut.
Thanks guys.
what the heck does that mean?
I would just like to know which wires to connect to which others to get the parallel-series set up I need to get 2 ohms out of this.
On your diagram....
1. Connect wires 1 and 3 to the positive side of your terminal.....
2. Connect wires 6 and 8 to the negative side of your terminal....
3. Connect wires 2 and 7 together...
4. Connect wires 4 and 5 together...
And theres your 2 ohm load...
fwb_1234
fwb_1234
Greenville, SC
perfecxionX
