Help w/Precision ports
sak384
I am in the process of building a ported box for (2) 12" JBLGTIMKII's using precision ports. Included with the ports is a formula to calculate the length needed.
.................2
Lv=8466.4R
....._______.......-1.463R
..................2
...... (Vb)Fb
Lv=port length in inches
Vb=volume of box in cubic feet
Fb=tuning frequency
R= radius of port (1/2 of port diameter)
My subs call for 2.25 cubic feet,tuned to 39hz, with 4" port length of 13.31"
Before i cut these ports ii would like to double check and this does not work for me. Anyone understand this...
please ignore the dots used as spacing cause the editor adjusts them all the way over
use the port calculator on their site and see if they match, if they do, you did it correctly. remember that both port flares add up to 5 inches of useable port so substract 5 inches from your total number and thats how much tubing you should cut out
THANKS for the website siite link and guys for all your help. Using 2 independent chambers @ 2.25 cu ft each. Jbl says 13.31 , 4" port
website says straight length port req'd =13.80
Flare length port req'd = 14.80
they suggest addiing 1". what do you guys think?
the number you get from your calculations or the calculator is the total amount of port length you should have. the flares have 5 inches of useable port so you subtract 5 inches of the total length..giving you how long your tube should be
sak384
sak384
florida
Mattd0344
AJ (ACE)
    Jun 28, 2026
