help w/ coax cable
MikeofTulsa
Moderator
The one and Only!
guys what im looking for is a coax(rg6) cable connector that i can place on both sides of my window that sends the signal through the window so i can hook up my satellite dish w/out having to drill holes or run rg6 flatwire through my window. not sure what exactly they are called, i have seen them before. any help would be appreciated
not looking for a flat wire but that would be helpfull also. will have to see if i can use that or not. any other suggestions would be helpful
So, you are talking about something similar to like a cellular antenna on a car window where you have like a postage stamp size thing mounted on both sides of the glass?
its driving me nuts cause i know it exists i just cant seem to figure out what its called. anyways thanks for the help, however i disagree with your custom user text cause its the other way around, my kid>stones kid
Only one way to settle this, CAGE MATCH!!//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
i'd win that for sure dont think its fair for me to fight a kid //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif anyways, back on topic
GlassLink™ Coax Thru Glass Device - RG6 coaxial cable right through your window...with no holes! No need to drill holes through your outside wall to get cable inside. Works like the cellular phone antenna on your car. Glass Link attaches to both the inside and outside of your single pane glass window and passes the satellite signal right through the glass. Perfect for apartments, condominiums and military housing.
Not for use on tempered or dual pane glass. Because installation of GlassLink is permanent, returns cannot be accepted on this item.
MikeofTulsa
Moderator
The one and Only!
MikeofTulsa
Tulsa, OK
MikeofTulsa
