Help Tuning a New Headunit and 2 Amps
  • 1
B1GR3DDD
Delaware
After dealing with some very annoying ground loop problems for many months, I have finally got my system to exactly where I wanted. I can finally turn my volume down to 0 and hear absolutely nothing, no annoying engine whine noise anymore!
In the process of fixing things, I had to get a new head unit. With the new one, I now have 4 volt pre-outs. I'm not positive about this but I do believe that plays a role into the output levels if the amps were previously set to receive a 2 volt signal. The loudest I am comfortable turning my head unit up to is 15, as before I would go up to 35. Along with this, the EQ is completely different. Songs with heavy bass that would turn my rear view mirror down now barely even hit.
So my question is what steps should I take to tune my system to where the levels are set properly and to where I enjoy the playback frequencies? Note I have a 4 channel and a bass amp.
I'm also curious about how I should find the maximum volume to turn my deck up to? Should I simply turn the gain all the way down on my 4 channel and then listen for the distortion with it being low?
I'm starting back at square 1 with this so any help would be very much appreciated.
Thanks Guys!
Did you say you dropped it off at the autoshop? Well that's the problem. Not all all mechanics are made alike. Even if they are ASE certified...
Turn the subwoofer output to max. Turn the gain down on the amp to where you're comfortable the the amp isn't clipping. Play a 0db sine wave at...
17
I may have missed it, but do you have sound deadener on the doors? If not that could be why you're lacking midbass.
915
Do you intend to drive around playing test tones? If your intention is to play music, you should be using music you intend to play to dial in...
B1GR3DDD
B1GR3DDD
Delaware
B1GR3DDD
