smidge710
ok guys so i just bought a used 2005 wrx, which already has a system of sorts installed. i have not taken off the door cards to see what is in there, but i know i have my regular set of speakers/tweeters in the front. and also a set of speakers/tweeters in the rear. as well as a 12" sub in the back. I have 2 amps. one is a soundstream rubicon 204. the other is a rockford fosgate. So this is what i know: sub is hooked up to the rocford fosgate amp. speakers im guessing are hooked up to the other one. (from research ive done it is a 4 channel amp). now here is where i get confused. i went to install my headunit (ddx470) and well there was only two sets of RCA cables coming in. One im pretty sure is for the sub as it came out of the subwoofer connection for the other headunit. and the other ones i plugged into the connectors for the front speakers, but when i use a fader for front/back it sounds like all of the rear speakers/sub are all on the same channel.. it did not even sound like i was getting sound from the tweeters. if you guys want/need pics ill be glad to provide some. thanks.
