help! stock mitsu eclipse , wiring help!
  • 2
HELP!
i have a 2000 mitsubishi eclipse
i got a receiver as a present for christmas.
so i go to install it and... well...
the built in amp for this stock infinity system is killing me... //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
how can i wire the amp into the new receiver?! //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif !? there's got to be a way! //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i know the factory amp is cheesy but no money = work with whatcha got
I have a 2003 3G w/ premium sound package. You have to bypass the factory amp when you install your new HU. Just T-tap into the DIN connector and unplug the amp from everything. You'll need a DVOM (Digital Volt/Ohm Meter) to know what speaker wire goes to what speaker.. You'll also have to run new speaker wire from the HU to the old amp.
I did exactly this while I saved up for Infinity Perfect 6.1's and a Visonik V4208 amp to replace everything with.
335
280
2000eclipse
2000eclipse
ft walton beach, FL
Mungla
    May 24, 2024
