Help setting gain
aeon
CA
Well I read through all of the articles and searched through a bunhc of thread on how to set my gain.
I have some diamond audio d361 speaker
Type: Component
Size: 6 in.inch Mid 1 in.inch Tweet
Power Handling NOM/MAX: 60/120 watts
Sensitivity (2.83V/1m): 91 dB SPL
Freq. Response: 54-20
Mounting Depth/Diameter: 2.5 in. / 5.4 in.
and a diamond audio D3400.2 amp
Type: Full Range
Channels: 2
RMS @ 4 Ohm: 100 x 2
RMS Mono: 400 x 1 @ 4 Ohm
THD: 0.05%
Crossovers: Low Pass, High Pass
I used a volt meter to measure the output to each speaker and I set the gain so that 20 volts was the output. Is 20 volts the correct amount? Well the problem I'm having is when I turn the volume up a little pass have way, I get some really weird noises. Like cracking and thumping noises.. Am I give the speakers to much power or is it another problem? I've also checked all of my grounding.
well tried turning it down still the same problem. turned it all the way down and still have the same problem... any other suggestions?
aeon
aeon
CA
aeon
