Help, Programming HW, MIPS
kentb
so here is the procedure in MIPS language
for calculating Fibonacci number(Recursion)
# Display fibonacci sequence.
# The Fibonacci Sequence is defined as follows:
# fibonacci(n)
# if n=1 or n=0
# fibonacci(n) = n
# if n >= 2
# fibonacci(n) = fibonacci(n-2) + fibonacci(n-1)
# Arguments:
# $a0 - n
# Returns:
# fibonacci(n)
.globl fibonacci
.ent fibonacci
fibonacci:
####Save registers####
sub $sp, $sp, 8
sw $ra, ($sp)
sw $s0, 4($sp)
move $v0, $a0 #number to $v0
ble $a0, 1 , fib_done
move $s0, $a0 #copy the number to $s0
sub $a0, $a0, 1
jal fibonacci
sub $a0, $s0, 2
move $s0, $v0
jal fibonacci
add $v0, $v0 ,$s0
fib_done:
####Restore Registers####
lw $ra, ($sp)
lw $s0, 4($sp)
addu $sp, $sp, 8
jr $ra
.end fibonacci
just need to make a procedure that calculates Perrin number
my prof said you just need to add a couple of lines of code on the fibonacci sequence procedure.
here is the formula
# Display perrin sequence.
# The Perrin Sequence is defined as follows:
# perrin(n)
# if n=0
# perrin(n) = 3
# if n=1
# perrin(n) = 0
# if n=2
# perrin(n) = 2
# if n > 2
# perrin(n) = perrin(n-2) + perrin(n-3)
# Arguments:
# $a0 - n
# Returns:
# perrin(n)
idk if there are programmers here. but fu.ck it, might as well try
so here is the procedure in MIPS languagefor calculating Fibonacci number(Recursion)
# fibonacci(n)
# if n=1 or n=0
# fibonacci(n) = n
# if n >= 2
# Arguments:
# $a0 - n
# Returns:
# fibonacci(n)
.globl fibonacci
.ent fibonacci
fibonacci:
sub $sp, $sp, 8
sw $ra, ($sp)
sw $s0, 4($sp)
sub $a0, $a0, 1
jal fibonacci
sub $a0, $s0, 2
move $s0, $v0
jal fibonacci
add $v0, $v0 ,$s0
fib_done:
lw $ra, ($sp)
lw $s0, 4($sp)
addu $sp, $sp, 8
jr $ra
.end fibonacci
here is the formula
# perrin(n)
# if n=0
# perrin(n) = 3
# if n=1
# perrin(n) = 0
# if n=2
# perrin(n) = 2
# if n > 2
# Arguments:
# $a0 - n
# Returns:
# perrin(n)
Man, I can't remember much of the assembly language stuff. It shouldn't be hard, you're doing the same logical process with a different algorithm. You have an integer as input and depending on the value of the integer, you want to perform one of 4 operations on the integer and return your output similar to what your fibonacci routine does. Unfortunately assembly doesn't read well and its been 6 years since I've done this so you'd have to clear up a couple things before I can fully realize what the program is doing. I can read C and Java any day but not assembly.
Is this doing a less-than-or-equal-to-1 comparison to $a0, and jumping to fib_done if true?
jal fibonacci
What does this line do?
For the Perrin sequence are you wanting to modify the fibonacci number and return that as output, are you calculating the Perrin number on the same input integer and having that output in addition tot he fibonacci number, or what?
kentb
kentb
Las Vegas
low00ranger
