Help... Plz
kwitcherbichin
Ok I Posted A Thread Last Night Sayin What I Got And What I Wanted To Do... But No Replies.. So Ima Try This One More Time And Hopefully Get Better Results
2 12 Re Xxx D2
Made A Box The Other Day Just 2 C What They Sounded Like Not Impressed So Far Cause Of The Lil Power I Have On Them. But Anyways The Box I Currently Have Is To Tall By 1/2 Inch To Fit In The **** Trunk So Ima Make Another Box Asap That Will Fit In The Trunk And Here Is The Design That I Was Thinking
Make The Box To Max Size I Can Fit In The Trunk And Then Make The Port To Where I Can Change It. Example: Port One Low As Hell Maybe 19 Hz And Then Another Port Around 33 For Daily Music And The Reason I Want One Taht Is So Stupid Low Is Cause I Got Kinda A Rivalry Thing Around Here I Live.
Ill Explain A Lil More If Someone Replies To This Thread And Doesnt Understand It...
at 19 hz....you would need a box that is huge for those subs to be low end monsters.....so you better off just sticking with the 33 hz tune and a box that fits your trunk
Well The Box I Have Now Is Spos To B Tuned Around 28 Hz And I Kno Thats Way Different From 19 So I Guess Ill Try Maybe 25 Hz At The Lowest But Have Yall Ever Heard Of Someone Makin Ports That They Could Change?
yes its called interchangable ports...they are great...but not when you are trying to be a low end monster and a daily monster...you have to pick one or the other
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
Can you sell the LOC and buy a head unit for that price that will do all of what both of those things would do?
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
If you haven't located the short...reconnecting everything can go the wrong way at the worst time...
26
kwitcherbichin
kwitcherbichin
stantonsburg, nc
mazdakid
    May 16, 2024
    May 16, 2024
