help please...
fngizmo7
Mass
I have a Sony CDX-M8800 CD/MP3 Player Installed. Everything worked fine for about 6 months, until I discovered a short near the sub-woofers. It blew a few fuses on the amp. After replacing the fuses on the amp, the amp worked for about a few hours then the system shut off. So, I thought it was the amp and have since got a new one. The new amp, now has power, and everything is installed properly. The subs are still working fine (tried them out in my friends car). I also tested the rca's to make sure there wasn't a pinch or something in the wiring back to the amp and it was passing signals fine. The only thing I can think is that the Head Unit itself is not sending a signal to the pre-outs.
Has anyone ever heard of the pre-outs burning out? Can this be fixed?
I already reset the radio itself and that didn't work. The inside speakers work fine, its just not sending any signal to the amp. Also, I don't have another HU with pre-outs to see if another one would work. Any suggestions?
So your not getting any bass from the amp??? Try some new rca's.
I tested the Rca's by putting another speaker up to them (bare wire, outside rim is negative, pin of the rca is positive). So basically i hard wired one of the inside speaker wires to test both of the RCA wires. they both work.
fngizmo7
fngizmo7
Mass
fngizmo7
