Help Please!!!!
J_AUSTIN69
I JUST BROUGHT
1.KENWOOD KVT-715DVD
2.KENWOOD KGC-9044 11 BAND GRAPHIC EQ
3.KENWOOD (KDS-901) DVD SURROUND PROCESSOR
4.JL AUDIO 500/1 500 WATT MONO AMP
5.JL AUDIO 10W7 10'' SUBWOOFER (2EA)
6.JL AUDIO 300/4 FOUR CHANNEL AMP
7.JL AUDIO XR650-CW 6 1/2 COMPONENT SPEAKER SET
8.JL AUDIO XR570-CX 5 X 7 COAXIAL SPEAKER
LOOKING FOR WIRING DIAGRAM FOR THIS SYSYTEM THAT I PURCHASED AND ANY ADDITIONAL ITEMS THAT I MAY NEED FOR MY 2003 GT CONV MUSTANG. ALSO DO I NEED A LIGHTING CAP FOR THIS SYSTEM AND WHAT GAUAGE WIRE SHOULD I USE. ANY HELP WOULD BE APPRECIATED. //content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif
Don't worry about the cap, If you have dimmage.. let us know and then we'll tell you how to fix it without shelling out bux for a useless piece of gear.
for wire run 2 awg from the battery back to a d block. from the d block run two 4 awg lines to your amps. Fuse the main line at the battery with a 200 amp fuse. At the d block, the two other lines fuse them both with a 100 amp fuse each. or something like that. Remember, these fuses are just to keep the wire safe from overdraw (aka fire!).
So you need:
20 or so feet of 2 awg power wire.
6 feet or so of 4 awg ground wire.
8 feet or so of 4 awg wire
3 fuse holders
1 200 amp fuse
2 100 amp fuses
1 Distrobution block with 2awg in and 4 awg out.
as for a wiring diagram.. do you mean for the deck? If its new, it should have come with one. Also, pick up a factory wiring harness for your car from best buy or something. I believe the metra part number is 70-1771. But they can tell you for sure.
Good luck and let us know if you need anything else.
J_AUSTIN69
J_AUSTIN69
CHICAGO HEIGHTS,IL
J_AUSTIN69
