Cd player question.....
GrandAM12
I have Pioneer DEH-P6600 cd player im about to hook up my system.... before i start i wanted to get an idea....now my question is there are think two pre outs on the back so does it matter which one i put them in and for the led wire...is there a special place for it on the back of the cd player or must i connect it the wires together?!?!!? A full descripition would be nice if possible.
Ok from what im reading most of the time the wire is blue that you connect the lead wire too. I bought the connector you plug straight into the factory then it goes into the pioneer cd player. Now i see on the connector there are two blue wires...one is solid blue and the other has a white stripe. The solid blue one goes from one lil slot and bends back into another slot....is this where i connect my wire at?!?!?!?! Please need some help.
Ok i just need to know which one is the led wire... i figured it out you just connect the led wire to the led wire to the cd player. But im just curious which one is the led wire... the blue one?!!?!?
yes blue/white... on pioneer it doesn't matter because they only have one blue wire coming out of the deck... and yes it does matter which preout you hook your rca's into... are you running subs? front speakers or rear speakers? if subs... connect to sub output... rears... rear output... fronts... front output...
GrandAM12
GrandAM12
CLEVELAND
GrandAM12
