help please with amp specs
it appears to be common to a few manufacturers these days... esp. if you can run less than a 2 ohm load. If you have 2 4ohm drivers and wired one to each output, your amp will see a 2ohm load in mono...if just one output is used, make sure it doesn't see less that 2ohms on that amp. now here is the kicker, say you have a 4+4 DVC driver...which output will you use? confused yet?...six in one, a half dozen in the other.
wait so if i put a sub that runs at 2ohms it will get 360 even though its only hooked up to one channel?
im sorry im confused. so with my sub rated at 2 ohms it will get 360rms even though its only going to be connected into one of the two terminals on the amp?
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Hey everyone.. sorry I didn't get notified that i has more responses to this thread. The porsche sold a couple weeks ago lol I'll miss it but I...
29
4K
I’d suggest taking a methodical approach. Start with things you know work. Then add one thing at a time. Test the addition with a scope. Keep...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
ccapital83
ccapital83
NY
ccapital83
    May 31, 2024
    May 24, 2024
