jco1385
expert jcologist
maybe you need to upgrade the headlight wiring. i know some cars (like mine) it can be done, and yields better output
blue=yellow, optima just says the blues are to be used for marine useI always heard the blue was retarded for car audio also.
Yellow is where its at.
Depends on which blue. Some are deep cycle, some are deepcycle/starting. The blues are a little nicer cause the have batt posts and a threaded stud. They have stainless terminals too so they dont corrode.I thought it had more to do with the CCA and voltage than the marine/car implications.
I agree.. But it was a Deep Cycle, so I figure the loss of the CCA for the Deep Cycle would still be better than my stock Batt...if you have a 550cca battery that is MOST LIKELY your problem... that is such a small battery I wouldnt be surprised if a lawnmower brick battery had more juice than whatever you had in there.
what?is that with the car on? if so it sure doesnt sound very good.
When I say "installed', I mean along the lines of wiring and whether or not the right rague wire was used. If you can provide us with the spec on the alt, it might point toward an obvious problem such as X amperage at Y RPM.Got the blue top.. dunno if im gonna have time to put it in today/ or until after the weekend. Ill update once I get it in...
I dunno how an Alt. is installed, but I thought it was just the 3 bolts and the 1 pulley.
