Help Picking Very Powerful and Clean 4 channel amp to power CDT Components ...
CDT SQA-4140 will also provide a continuous maximum of 280 Watts bridged from each of two pairs of channels into 4 Ohms.
So this would pump out 280 watts @ 4 ohms to the front pair of CDT Comps and then another 280 watts @ 4 ohms to the rear pair of CDT Comps ...
I was thinking that the ohms would go down to 2 when bridged and going to all 4 channels ... Correct ... thus equaling 140x4 at 2 ohms ... right ?
Your confusing bridged with a reduction in ohms. You do need to read up some.
Regardless, the amp will suit your needs, they are ZED amps.
Your confusing bridged with a reduction in ohms. You do need to read up some.Regardless, the amp will suit your needs, they are ZED amps.
Here are the specs for the ZED Draconia ...
Continuous Output Power into 2 ohm per channel ... 140wx4
Continuous Output Power into 4 ohm per channel ... 70wx4
Typical Output Power into 4 ohm per channel (0.8% THD) ... 95wx4
Continuous Output Power 2 channels bridged into 4 ohm ... 280wx2
Continuous Output Power 2 channels bridged into 8 ohm ... 140wx2
Maybe the CDT Amp mentioned isn't exactly the same as the Draconia as I was thinking ... if The CDT can do Bridged 280x4 @ 4 ohms ...
Am I missing anything here?
Ok. Now and try and find some CDT amps. From what I have seen same problem with trying to get Zed. Before anyone goes all bonkers about getting some CDT amps see if you can even find them.
The authorized retailers on line everywhere I have seen no longer even have them listed.
This goes back to trying to get Zed stuff which can be very difficult. Depends on when the next time Zed makes a run of amps. Great stuff just hard to get. Which appears to be the same for the CDT.
I could be wrong so do some checking to see where you can get your hands on CDT amps or contact CDT directly. I have never seen a review of a CDT amp or no anyone that owns one. Could be a reason for that, just a thought.
You just told Dejawiz he needed to read up some, must have been a joke. Did you even read that on DIYMA or was it just to technical for your feeble brain.
Read and learn.
Also if he bridges how the hell is going to run the rears. He will need more than 100w per side to run just the front comps. He needs to keep the front around at least 150w to 200w per side.
Having run the CDT HDM6 it needs a good clean 100w and would be better with 125w.IMO
No need to call names to voice your opinion.
You misunderstood my post,
If he is using
A set of M6's with the ES-01 Tweets and 560i crossovers ... and
A set of EF-61CF's with the TW-25 Tweets and 560i crossovers
he is running a passive system, so the two pairs of tweets and mids will not see a 4ohm load, the load will typically be closer to 2ohms. The amp I recommended has right at the power he was looking for at a typical 2 ohm load with 4-channels. Those amps are also under rated. The Draconia is the only Zed amp I know of that is out of stock, this is a CDT amp.
No need to call names to voice your opinion.You misunderstood my post,
If he is using
His passives are 4ohms. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
1. he is running a passive system, so the two pairs of tweets and mids will not see a 4ohm load, the load will typically be closer to 2ohms.
Are you meaning to say that if 2 sets of 4 ohm comps are wired in parallel to a single amp channel it'll provide that channel with a 2 ohm load?
Tim_in_NC
Tim_in_NC
atlanta
DejaWiz
