Help, one channel lost power
Hernan
I run an active setup. Three way components and a sub. I powered the system with two 4 ch amps. The left channel moving the midbass sometimes lost its power. It is still some signal feeding the driver. If the system is restarted, sometimes it began to work normally. Sometimes if I crank up the volume it lost its power. ???
The RCA signal from the stereo is ok, as the misbass shares the same input with the midrange and tweeter and these work ok.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Thanks!
Hernan
Hernan
Buenos Aires
SAG3
Mike Mccabe
