Help on wiring
biiqdanz
Ok... i have a rockford 700's with two 12 inch mtx thunder 8000's dual 4 ohm subs. Now both subs came with a paper on how to wire the subs. But as of now im not using the other 2 coils. Im just using two on each sub so im doing a single voice coil wiring.
Theres an option to wire 2 subs.
It says
With speakers wired in parallel:
Two 4 ohm speakers will present a 2 ohm load----- thats what i did but it isnt working i dont know why any help?
First off, u absoulutley need to use both voice coils on the sub, no exceptions! And then wire one sub's voice coil in parallel to get a 2 ohm load, wire your other sub the same way to get a 2 ohm load, then wire the subs either in parallel to = 1 ohm, or in series to = 4 ohms,
OR
Wire one subs coils in series to be an 8 ohm load, wire the other sub the same way, and wire the 2 subs in parallel to = 4 ohms, or wire the 2 subs in series and get 16 ohms.
Those are all possibe outcomes with two dual 4 ohm voice coil subs.
I hope that helps :)!
The subs will work with one coil, but it is not good for them as far as i know, unless it says specifically that it is ok,
And another suggestion, the way you have it, single parallel to single will = 2 ohm, so check and make sure your amp is stable at that low of an ohm load.
It says
Well wut i did was ok im gonna be specific lol. My connection was normal from the amp to the back of the box. then i took the subs out i cut 4 wires that were in my garage and i turned one sub around and i put a wire that went from positive to the other positive on the other side of the sub and i did the same thing with negative and i did that exactly to the other sub. So that presents a 2 ohm load with the rockford 700's //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Well the paper that came with them, has single voice coil wirings and on the back of the sheet it has dvc wiring so i assume it works. I just didnt wanna push it that hard. because this setup i have now makes my radio skip but ill deal with it lol because its the stock one so i have to deal with the skip of the cd due to the bass. Thats why i wanted to keep it parrellel 4 ohm load presents a 2 ohm load but on the paper it showed it differently then how someone showed me it here. I guess its because the amp didnt recognize it i dunno. But the amps specs are 175 with 4 ohm load 350 on a 2 ohm load- thats the one i have and 700x1 on 4ohm Load bridged (mono). So if that helps did i do it right? I checked it and it worked good but i wanna make sure the amp doesnt blow in time?
for future refrence-
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
your amp specs;
Rockford Fosgate 700S
* Amplifier Type: 2-channel
* RMS Power: 175W x 2 @ 4ohms per channel
* RMS Power: 350W x 2 @ 2ohms per channel
***Bridged RMS Power: 700W x 1 @4ohm bridged MINIMUM***
* THD at Rated RMS Power:
* Speaker Level Inputs: Yes
* Preamp Outputs: No
* Built-In Crossovers: HP/LP
* Bass Boost: 0 - 18 dB
* Frequency Response: 20-20,000 Hz
* Channel Separation: 65 dB
* Signal to Noise Ratio: >100 dB
* Fuse Rating: 60 amps
your user manual *print this out for future refrence if you dont have it*;
http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/fattach_get.php?p_sid=J2yKfsth&p_tbl=9&p_id=278&p_created=1083252061
so here is how you hook it up if you bridge @4ohms;
but you can also wire the DVC4 coils each to 2 ohm like so and hook them to each channel - both ways *should* get 700w, but who knows how much that amp is overrated - this is how I would do it... just incase one woofer decides to break, the other will be wired by itself and there will be zero problems if one goes;
good luck //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
your amp specs;
So your amp bridged will only take a 4 ohm load or higher. So that is your problem, too low impedence. use both coils, get it to equal 4 ohms total, and then run bridge your amp, no problem.
your amp specs;
So the way i set it up was wrong or can cause the amp to blow?
Originally Posted by bonesninja
http://www.jlaudio.com/tutorials/wiring/ scroll down to the second diagram the one that says 1 dvc driver with voice coils in parallel. do each sub like that then connect one sub per channel.
Go there.. thats how i wired the 2
biiqdanz
biiqdanz
new jersey
biiqdanz
