Help on sub and port placement in boat??
You are able to get quite a good amount of room for that, which is a good thing! As far as placement, due to the fact that there is little acoustical resistance in nearly 2 planes, the best type of setup may be direct firing or either downfiring to help with loading of the driver.
With a direct fire, you will likely get a better output, and with the downfire, you may get a bandpass type of sound from that environment. And those differences will depend on what you are looking to obtain with your sound. You can either have a bandpass type of sound with a very low end tuning, or a direct SQ type of sound with a likely high tuning(not exceeding 45-50Hz) for the best output in your boat. I would not tune to low on this, as that may cause some degree of loss in the upper region as the gain will have a huge drop for most of the output, much like designing for a large room, where most of the gain may be a loss.
SO, high power, direct placement may be the optimal choice.
Hope that helps!
brad03cobra
brad03cobra
huntsville,al
Moble Enclosurs
