help on some 15s
dride
right now i have a single 12" tc3k running off a Hifonics BXi 1206D..i want more bass so im going to upgrade to 2 15's..i want to use the same amp so i have 500-600rms for each sub to play with...its going in the trunk of a 97 acura tl i have 42ish wide 20 high and about 22 deep..wanting to go ported if trunk will allow..and tring to keep the subs in the 300 range for the pair..i was looking at some cvrs..input would be appreciated
id recommend A LOT more power on the 3k b4 the 15s.
it will probably be very happy with an orion 2500d on it = 2500 wrms
if the 3k stands for 3000 watts, your badly underpowering it and that is why your bass sounds weak,
bigger subs wont solve your problem.
why not buy another amp it would be cheaper and you wouldnt notice a huge diffrence in diffrent subs with same amp...
i was tryin to get the most out of wat i got for now..eventualy i want to upgrade my alt and put some batteries in the trunk so i can go real loud..i dont think my electrical can take too much more without me starting to ruin stuff..i guess i might have to start saving so i can upgrade my electrical and run more watts
tc-3000=1000rms 1500 peak
so maybe my question is would 2 15 inch cvrs or 2 15 incht1's on my 1206d hifonics hit harder than my 12 inch tc-3000..both ported
and would a hifonics 1206d even give 2 t1s enough rms..thier rated 600 and my amps 1200 i kno thats not really wat its givin
dride
dride
tracy, CA
60ndown
Mike Mccabe
