Help on SA-10s
I did a lot of research on what subs i wanted along time ago but had no money and now that i have the money i forgot the difference between buying SA-10s dual 2ohm or SA-10s dual 4ohm. I know you can wire down to 1 ohm on one of them but im not sure if i want to wire down to 1 ohm cause iv heard its not as clear of a sound. I heard the higher ohms the more clearity and lower the more it hits harder.
Idk if i sound like an idiot but please refresh my memory.
You won't hear a difference in ohm loads, at least not with subs. And one impedance doesn't make your sub hit harder than another, it's all on what your amp puts out..
Wiring it to 1 ohm you want the dual 4's. With dual voice coils you can wire each sub individually in series or parallel. I.e. wire a dual 4 sub in parallel down to 2 ohms, and then parallel the 2 subs together and you get 1 ohm.
Reece Cook
Reece Cook
Gonzales, Louisiana, United States
Kangaroux
