help on mustang l7 box
is it going in a new mustang or old cause if it is like a 92-2005 it wont fit like that....max height would be 12 then....those cars are *****es to work with
max height is 12" unless you remove the mach 460 box under the rear deck and then with the rear seat removed bend the metal along the top. i have been able to squeeze a box with a height of 14.5 in the trunk
... and yes they are a pain to work with
so i can get the box to fit if it's 14.5 like the dimensions i posted?
ok
My mustang didnt have mach system, so no amps underneath..i was going to do 14'' but i measured and max hieght was too small..so i cut down to 13 and 1/4'' and even that was a tad bit too big..i had to hammer in the border a little to slide it through cause i had a bump in the trunk! max height i wouldnt suggest going over 13'' ! 12 to be safe!
and yea...these cars a ***** to work with! i have no trunk space!
its an 02 mustang .. but how bout if i hammer that bump ?
beatinthablock
beatinthablock
EST,TX
UCF52
