help on install
put 4 stacked or in a line in the rear behind the rear seat and 2 in the rear side panels and 2 in the door or make a kick panel....all of these will require a custom made box....good luck....
I think your best bet is to ditch the 8 12s since every idea posted so far you have shot down. Theres plenty of options out there where you can spend the extra money for a better sub and get the performace of 20 crappy subs. I dont know what subs particular you had in mind but you might as well just use less subs and give them more airspace to work with. Find a few powerful 15s and if you do it right they will hit just as hard or even harder than 8 12s. Too many people dont realize how much design can effect the performance of their system. If your set on your 8 12s but dont want to move your backseat or take up your whole bed you can try just building a box that takes up say half of your bed with a cutout and a sock to your cab. Also check into seat raising kits for your truck and maybe youll find a little more room just depending on the model of your truck. Goodluck!
thanks for all the replies, i have decided to make a box in the bed and get a bed cover, im getting 8 FREE id max's, (gift from dad and one of his freinds), thanks everyone for the help
Cool, sounds good to me, you going sealed or ported? Good luck and send me some pics when you got it done or in progress!!!! I'm really interested cause' my brothers looking to do a similar install...
sure, as soon as i get it done i will post it, im probaly going ported for 2 reasons 1) i live in texas, in the summer it gets like 110 at sometimes more air should keep my system cooler 2) ported gets a bit louder
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
4
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
That or with a TB, you either have an amp, or those early 2000 years on the full size tahoe, they were wiring them in series. It's most likely...
Can you sell the LOC and buy a head unit for that price that will do all of what both of those things would do?
7
Ricky Nichols
Ricky Nichols
Texas
ss3079
winkychevelle
    May 24, 2024
