Help on horns or componets
what midbass could compliment 109dB efficieny?
Not many, without having to choke down the horns a lot. 8" - 10" is the way to go when matching a mid with them.
the ID horns go down to 600hz dont they?
Only on a very steep slope, and you won't want to listen to them at extremely loud volumes.
A more realistic range would be 800-1khz.
I really dont know. I am kinda new at this my first system was 4 Solo Barics straped to 2 Rockford Fosgate 1001BD's. I am now steping into a hole new sound system and want the cleanest, clearest, loudest sound system that I can get out of this equipment. I am willing to listen to any advise from you guys.
I really appreciate you help.
I am in the bay area. I am using the 2 Zapcos for both JL Audio W7's 13.5. Why you think they both can run off one? I thought I would get more out of them with both.
you will probably get more out of them with both, but it is overkill, way overkill. what amp are you using on your highs/mids. i would go with a 6.0 if you are doing 2 channel.
horns do get very loud (especially with 40 wrms)
I have an Audiocontrol EQL on mines and the gains set low
my Seas ca18rnx mids are only getting 40 wrms @ 8 ohms and after much tuning, they barely keep up
MAYBE just the midwoofer. but putting any highs in the back will mess with the soundstage. but 1 set in the front should be all you need though.
2_many_projects
Young Jedi
2_many_projects
california
audiolife
BP1Fanatic
BP1Fanatic
