help on gross...
ports external? add the volume of the ports to the gross.
ports internal? subtract the volume of the ports from the gross.
cylinder area = (pi*r^2)*Length
find the displacement of the subs on fi's website and subtract them from volume of the box.
ports external? add the volume of the ports to the gross.ports internal? subtract the volume of the ports from the gross.
If I remember correctly you never ADD the volume of the ports. Think of the port as a closed cylinder - they can not add to the volume of the box. Now, they can subtract from the volume. The amount they take from the gross volume depends on how many inches of the port is inside the box.
some people think that when you run external ports you have to add their volume because it is more air that the sub with my using along with the volume of the box.
I don't calculate port volume into any of my boxes because I tune my ports off a Termlab to where the system is the loudest and i'm constantly changing them so their length is constantly changing so for me to add in the volume of the ports would be stupid because their volume is constantly changing.
It's more volume for the sub only because the port isn't in the box.
Look at it this way...
Fill your bathtub with water. Hold two bricks above the water. Did the water rise? No, there was no change in the total volume.
Drop the two bricks into the water. Did the water rise? Yes. The bricks add to the total volume.
Then explain to your Mom, wife, or girlfriend why you are washing bricks in the bathtub! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
//content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif
ok so im getting ready to tune my box for my btl 7.4838 is what i have before aero and sub displacment...psp cacultor ask for box volume and im not sure what to put in as the volume of the box will change when sub and aero is factored in
you designed it backwards.
now i will help you
well say that the sub is .25 cuft and the ports all together equal about .73 cuft
take your gross and subtract 1 cuft, put in your port info 3 6" ports 15" long
and see what it tells you.
tapout383
Just boughta Zone.
tapout383
Virginia
bjfish11
