help on damaged w7 sub
iilee
ok i bought this 8w7 on ebay and i tested it out and it had this weird vibrating sound coming from inside the sub. the sub was hitting but the vibrating was hella loud. i looked inside and the yellow spider platform was like ripped off from the cone. so what can i do to fix this? i tried gluing it but didnt work too well i think i ****ed it up more. has anyone had problems like this?
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:
throw it away?
im really not sure, im sure there is something that can done, but i highly doubt it will perform the way that it should without at least a little noise..
fuuck man has anyone had a problem like this and tried to glue it back together? whats the best glue to use. or is there a different better way to fix it
and what sub u think isnt a POS
one that you can buy and it works without a problem...
like everyone else has said, try ca glue or some other type of strong adhesive, if that doesnt fix it your only hope is to send it to JL. they may be able to fix it without a recone, but it wont be cheap and im willing to bet no matter how it works out, you would have been cheaper buying a W7 new to begin with. or what would have been a better option, not buying a JL product.
This is more of an issue with him getting the sub off eBay than buying a JL product, in my opinion.
See if someone local can troubleshoot and/or repair it, otherwise look at more affordable options that don't carry the price tag of a W7.
Just remembered, I have that same coaxial/comp set, BNIB, $245 shipped if you are interested. I have the matching coaxials, took these of the...
200
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
199
634
iilee
iilee
san jose, ca
808skindiver
    Jun 15, 2024
    Jun 15, 2024
